aonavy1
Nov 02, 2019Guide
Do you guys hear a fan on your RAX120?
Ive been having nothing but issues with this router and today noticed I dont hear the fan coming on. Do you guys? Im wondering if this thing is over heating because the fan is not working. Thanks...
arjewell23
Feb 22, 2020Star
I found your post searching for fan settings as well. My fan wasn't turning on at all and my router was very hot. I think I found the answer after searching for a while. I posted this on another message as well. In your browser, type in "ip address/debug.htm". In the middle of the page is a setting to select "Always enable Fan", check that and click apply. The setting saved for me and my fan is now on. HOT air is blowing out, finally!
- Elie973Aug 16, 2020Aspirant
Hi, i can't find that fan setting, what firmware version are you using ? please
- plemansAug 17, 2020Guru - Experienced UserWhen you type the address, replace the ip address with your routers actual address. so if you're default address is 192.168.1.1
then you'd type 192.168.1.1/debug.htm- Elie973Aug 17, 2020Aspirant
I can acces to the /debug.htm page but there is no button for the fan, i running the V1.0.2.98_1.0.54 firmware
