trixtri
Nov 28, 2020Aspirant
do you need a modem to access the internet with an RAX50?
everything else working but wont pick up the interset from a connection that works perfect for another free router that came with the fibre order, diagram says it needs a cable modem before the fibre...
trixtri
Thanks for the response, I had a talk talk free router there preschools with no modem which works well, but the RAX50 has all lights set to go except for the internet. What setting would change and where would I change them?
I heard if the provider only allows one MAC number you have to clone and mask the Ax50 to be the same?
michaelkenward
Nov 29, 2020Guru - Experienced User
What TalkTalk service is this?
Mostly TalkTalk offers VDSL (fibre to the cabinet) with very few areas with "fibre to the premises".
So there's a high probability that the TalkTalk "free router" was really a modem router. If so, then you'll need something in front of the RAX50, which is a plain router.
If you still have the TalkTalk box you can try that in front of the RAX50. Ideally you should put it into modem only (bridged) mode or you could have problems with two routers messing around with each other.
Not knowing more about your system it isn't possible to be clearer than that.
I suggest a bit more research with TalkTalk. It isn't really a Netgear problem.
Start here:
ForumIndex - TalkTalk Help & Support
- trixtriNov 29, 2020AspirantBig thanks michaelkenward, makes sense and I did think of trying that but seemed to negate the idea of having a super router... if it doesn’t offer that facility and only fast Wi-Fi, is it the right solution for me, I will feed back the results abs again, 🙏
- michaelkenwardNov 29, 2020Guru - Experienced User
Make and model of the TalkTalk modem/router?
BT goes out of its way to prevent users from putting its modem/routers into modem-only mode. But not all ISPs are that evil.
it is an old Hawaie router from 2017 gives speeds of 100mg ethernet cable, its not a modem either so it cant be that and i guess i could use it to daisey chain with the Nighthawk, but doesn't make sense, do you know about the cloning of an exciting MAC address, as is suggested in the manual 'Configure your router to clone your computer’s MAC address' or any other perhaps its a provider security and i need to contact them?
thanks MK
