trixtri
Nov 28, 2020Aspirant
do you need a modem to access the internet with an RAX50?
everything else working but wont pick up the interset from a connection that works perfect for another free router that came with the fibre order, diagram says it needs a cable modem before the fibre...
Newfiedrool
Dec 03, 2020Virtuoso
https://setuprouter.com/router/huawei/hg633-talktalk/manual-1872.pdf
that's your routers manual, see bridge mode but it's an old router and maybe worth considering finding a modem second hand like the HG612.
if however this is too confusing I would recommend you find a local company who can look and install your router for you so at least it's set up ok as you are struggling a little bit to understand the help given to you.
michaelkenward
Dec 03, 2020Guru - Experienced User
You can say that again.
If trixtri is on DSL, the choice is limited and shrinking. Netgear and other makers seem to have abandoned the DSL modem market. There are some modem/routers out there, but they come with problems, especially if you want one is a router front end.
I ditched a D6400 in favour of the DM200. The first I bought retail, but by the time I cane ti buy a second modem, for my ither5 line, the DM 200 had vanished from the retail chain. I ended up buying an "open box" one at about the same price. It turned out to be "as new", with the usual plastic covering. But it is now down to the second hand market, where prices can be silly.
But is trixtri on DSL. That remains a mystery, for some unknown reason.
That box is ADSL. Will it even do VDSL?
I know from experience that TalkTalk dumped its ADSL customers on Fleur Telecom. That forced me to switch to BT, which turns out to have better support than TalkTalk by a long stretch
Given the conversation so far, I reckon that this is excellent advice.
- trixtriDec 03, 2020Aspirant
Evening, agreed - if I hadn’t just spend £250 on this router that is not compliant with my set up, i would just call in the Feds, however, the reason i am here is to get some cost effective advise from you kind professionals!.
so where I have got to, and apologise its incremental, i am not network slick in case you thought otherwise!
I have a HG633 that is set to VDSL, verified by looking at router settings - i cant see any reference in the RAX50 manual to VSDL let alone VSDL2 which is what i think my old HG633 does.
I think this is a deal breaker, as there is no point in me spending another £100 on a Modem (suggestion by amazon) as a companion to the RAX50 which i had hoped would be self-sufficient, so my bad I think.
The fact that none of this is clear anyway has turned me off the product/ brand really.
I just wanted good coverage for a large space working from home!
Anyway thanks for all your suggestions,
- NewfiedroolDec 04, 2020Virtuoso
It's the same with all routers, with all the various connections and configurations no manufacturer can cover it all in the operating manual. They leave that part to the end user.
Perhaps the HG612 modem which you can get of EBay for around £20 would be worth considering but if you are not use to networks it's worth asking around your local area if anyone can help, even your local Facebook page.
Once you learn the basics you will soon get the hand of it but just get a bit of help to start with. - michaelkenwardDec 04, 2020Guru - Experienced User
That is because DSL has nothing to do with routers. All a router like the RAX50 needs is an Internet connection from a box that has a wired Ethernet LAN output.
There are many ways of connecting a router to the Internet. The manual can't cover them all. For example, a couple of users recently asked about systems with a satellite dish at the front end. The manual cannot describe every way if connecting to the Internet, especially as it is not relevant to how you set up a router.
All the manual needs to do is to explain the process for getting on to the Internet.
Page 16 of the manual has a section Cable your router. It clearly shows that you have to plug the RAX50 into a modem.
That really answers the question that kicked off this discussion "do you need a modem to access the internet with an RAX50?"
The answer is in the manual.
Earlier on you wrote "if it doesn’t offer that facility and only fast Wi-Fi, is it the right solution for me". This suggests that you think that routers should also be modems.
You repeated that notion here:
As you now seem to admit, that was the first mistake. The RAX50 is not intended to be self-sufficient.
This conversation could have been a lot shorter, and completed much more quickly, if we'd had answers to the original questions about where your Internet came from, the equipment. But I can now see that you did not answer because you didn't understand why people were asking for that information.
A second hand DSL modem might be a good idea, if, thatis, your ISP uses DSL.
The ideal DSL modem from Netgear is the DM200.
The bad news is that Netgear, and most other brands, seem to have abandoned the market for DSL modem-only devices. Maybe ISPs are leaning on them in the way that they have for cable modems.
If you can lay your hands on something like the DM200, that would be a good choice. But the prices are getting silly. You may be able to find a second-hand one. I bought one from one of those "open box" merchants. It looked new, with all the usual packing and protection.
Netgear does sell modem/routers that you can run in modem-only mode, the D6400 for example, but, as I found, that can cause problems.
