txchuko
Jun 23, 2023Guide
Does anyone know what direction does the air flow on RAX70? (Image included)
Being that its summer I want to put a small 120mm fan but want to make sure I put it in the right direction
Jun 23, 2023Guru - Experienced User
Bottom to top.
Can place a fan under the router or on top.
Laptop cooler will work under the router forcing air up from the bottom.
I find these are effective as well:
