marinlee
Aug 31, 2024Aspirant
Does Nighthawk RAX50v2 Block Palo Alto Global Protect VPN
I work from home full time and my company is switching to Palo Alto's Global Protect VPN client and I cannot get the VPN client to work. Although we are troubleshooting with Palo, I am wondering if ...
alicemorgan3303
Sep 01, 2024Aspirant
It’s possible that your Nighthawk router is interfering with the Global Protect VPN. While changing DNS servers might help, you could also try disabling any advanced security features, like SPI Firewall or QoS, that might be blocking the VPN traffic. Additionally, ensure that VPN passthrough is enabled on your router. If the problem persists, try switching to public DNS servers like Google (8.8.8.8) or Cloudflare (1.1.1.1) to see if that resolves the issue.
