tmcmahan12's avatar
tmcmahan12
Follower
Sep 19, 2022
Does RAX 29 support MESH
1 Reply
  • plemans's avatar
    The RAX29 is a router only device.
    Does it support orbi satellites? no
    Does it support mesh extenders (like the EAX20)? Yes
    You can use mesh extenders with it. I only recommend using 1 mesh extender if you're running them with the mesh/single ssid mode. If you're needing more than 1 extender, the orbi or MK nighthawk is the more appropriate system.
