lvchen860217's avatar
Oct 11, 2019
Does RAX80 and RAX40 support 802.11 roaming protocol?
Does RAX80 and RAX40 support 802.11 roaming protocol?(802.11k or 802.11r or 802.11v)? If RAX80 is the main route and RAX40 is in AP mode, can it achieve seamless roaming?
  • Christian_R's avatar
    Christian_R
    Oct 17, 2019
    lvchen860217,
    Yes, if the EX7700 is in AP mode, the mesh feature will work. You will need to set the SSID the same on all WiFi interfaces.
    Christian
