lvchen860217
Oct 11, 2019Guide
Does RAX80 and RAX40 support 802.11 roaming protocol?
Does RAX80 and RAX40 support 802.11 roaming protocol?(802.11k or 802.11r or 802.11v)? If RAX80 is the main route and RAX40 is in AP mode, can it achieve seamless roaming?
- Oct 17, 2019
lvchen860217,
Yes, if the EX7700 is in AP mode, the mesh feature will work. You will need to set the SSID the same on all WiFi interfaces.
Christian
Christian_R
Oct 17, 2019NETGEAR Employee Retired
lvchen860217,
Christian
lvchen860217
Oct 18, 2019Guide
Thank you for your reply.
Although EX7700 supports 802.11k, but RAX80 does not. Are there some problems when roaming from EX7700 to RAX80?
- Christian_ROct 18, 2019NETGEAR Employee Retired
lvchen860217,
There should be no problems! However, if you do experience an issue(s), please feel free to let us know!
Christian
- schumakuOct 22, 2019Guru - Experienced User
lvchen860217 wrote:Although EX7700 supports 802.11k, but RAX80 does not.
Based on some early days Data Sheet where it was not listed (and initially not available) or what? The point is that Netgear does not update Data Sheets, User Manuals, ... very often.
