Teamdre84
Jul 12, 2019Tutor
Does the RAX120 support AirPrint?
Hello Community, I’m getting ready to upgrade my wireless router from an Apple AirPort Extreme to possibly a RAX120. My current modem and router are located in the living room physically connected t...
schumaku
Jul 13, 2019Guru - Experienced User
As long as your network (wireless Wi-Fi or Ethernet LAN) connected printer is reachable, and does support AirPrint, there should be nothing stopping you.
The confusion is coming from the USB Printer Sharing feature which is not available currently on the Wi-Fi 6 RAX router models: You can not connect a random USB printer [the USB sharing isn't in place] not supporting AirPrint natively and make it AirPrint capable using the Windows or MacOS desktop Genie.
