gehw
Apr 13, 2024Follower
Does the RAX30 support option 60/61 or sky MER
I currently have Sky Gigafast FTTP in the UK, I am trying to find out whether this router can connect directly to my fibre ONT taking the place of the isp router. From what I have seen online i believe for an external router to work over Sky fibre it needs option 60/61 although I'm still not too sure so if anyone knows if the router has it or even if i need it would be very helpful. Thank You
1 Reply
- KitsapMaster
gehw wrote:
I currently have Sky Gigafast FTTP in the UK, I am trying to find out whether this router can connect directly to my fibre ONT taking the place of the isp router. From what I have seen online i believe for an external router to work over Sky fibre it needs option 60/61 although I'm still not too sure so if anyone knows if the router has it or even if i need it would be very helpful. Thank YouI do not have an RAX30 to work with. On my R9000, you log in to the user interface, go to Basic -> Setup -> Internet Setup and scroll to the bottom of the page and then scroll to the bottom of the inset window. Fields for option 60/61 identifier strings are there.
