Kotus
Apr 11, 2022Aspirant
Does the RAX50 product support PMF? (Protect Management Frame)
Does the RAX50 product support PMF? (Protect Management Frame IEEE 802.11w)
microchip8
Apr 11, 2022Master
No
- KotusApr 19, 2022Aspirant
Hey microchip8, how can you tell?
Do you have a source of info for that, or is it based on your experience?
I am asking because I am trying to answer the same question for other Netgear APs.
- FURRYe38Apr 19, 2022Guru - Experienced User
PMF is mostly a business class feature and not seen on home class systems.
If you want PMF, you might review NGs WAC/X series if APs:
https://kb.netgear.com/000051206/WAC505-WAC510-Firmware-Version-3-1-0-12
Or Orbi Pro series.
