Kotus
Apr 11, 2022Aspirant
Does the RAX50 product support PMF? (Protect Management Frame)
Does the RAX50 product support PMF? (Protect Management Frame IEEE 802.11w)
Kotus
Apr 19, 2022Aspirant
Hey microchip8, how can you tell?
Do you have a source of info for that, or is it based on your experience?
I am asking because I am trying to answer the same question for other Netgear APs.
Apr 19, 2022Guru - Experienced User
PMF is mostly a business class feature and not seen on home class systems.
If you want PMF, you might review NGs WAC/X series if APs:
https://kb.netgear.com/000051206/WAC505-WAC510-Firmware-Version-3-1-0-12
Or Orbi Pro series.
