Moose141
Oct 14, 2022Aspirant
Doesnt allow more than 10 devices
I have the nighthawk RAX70. Everything I find online says this model can handle anywhere between 20 and 25 devices (depending on the source) Mine seems to boot a device off every time we get to 10 ...
Moose141
Oct 15, 2022Aspirant
The nighthawk is the R6350. I was looking into buying the RAX70 and copy and pasted the wrong model number. My apologies.
michaelkenward
Oct 15, 2022Guru - Experienced User
A very different animal. Not even a Nighthawk model.
Pretty basic. Nothing like the RAX70 which may well support all the devices that you expect to support.
How many clients can you connect wirelessly to a NETGEAR router? | Answer | NETGEAR Support
The R6350 should support more than 10 devices, but who knows how many connections your wifi clients really use?
- Moose141Oct 15, 2022AspirantFair enough. I think I'll just upgrade to the rax70 then. Appreciate the help
