olivethi
Nov 28, 2024Aspirant
Download slow
I've 1g in my isp. Even i test the speed in the modem it reach 500mb, but when I try either the router rax200 it reach only 90mb
Nov 28, 2024Guru - Experienced User
what modem do you have?
have you checked your wan/lan port statistics to ensure you're cable is connecting at gigabit speeds?
How do I display Internet port statistics on my Nighthawk router? - NETGEAR Support
- olivethiNov 28, 2024AspirantNokia G-1425G-A
- olivethiNov 28, 2024AspirantI put the cable in the internet port of the router. In the internet configuration is checked the internet port 1 gbps. In the wireless configuration is checked ax and ofdma for 2.4ghz and 5ghz
In mode both 1200mbps
In wan disable dos
