olivethi
Nov 28, 2024Aspirant
Download slow
I've 1g in my isp. Even i test the speed in the modem it reach 500mb, but when I try either the router rax200 it reach only 90mb
olivethi
I put the cable in the internet port of the router. In the internet configuration is checked the internet port 1 gbps. In the wireless configuration is checked ax and ofdma for 2.4ghz and 5ghz
In mode both 1200mbps
In wan disable dos
In wan disable dos
Nov 28, 2024Guru - Experienced User
a screensnip helps us to see that
- olivethiNov 28, 2024Aspirant
- olivethiNov 30, 2024Aspirant
Im sorry. Firmware Version v1.0.10.140
Serial Number xxxxxxxxxxxx
In the previous posts I put the screenshot as asked.- olivethiNov 30, 2024AspirantI've 1g in my isp. When I test the speed in the modem it reach 500mb, but when I try the wifi in the router rax200 it reach only 90mb.
I've ofdma checked. I'm using Google dns. The Isp modem is: Nokia G-1425G-A
In wan disable dos
