DearGeo
Dec 02, 2021Tutor
Drop connection
RAX200 Nighthawk keeps dropping wired connection. I have narrowed it down to my router. I have soft and hard reset, rebooted modem and yet it doesn’t work. Firmware is up to date. I thought it was my ...
Dec 02, 2021Guru - Experienced User
Is it only xbox game console dropping the wire connection or do other wired devices drop the connection as well?
DearGeo
Dec 02, 2021Tutor
Netgear CM1150v. - which I stopped using after I got Frontier FiberOptic - which doesn’t need a modem and plugs in from the FiberOptic switch box to RG45 on the back of my router.
