DearGeo
Dec 02, 2021Tutor
Drop connection
RAX200 Nighthawk keeps dropping wired connection. I have narrowed it down to my router. I have soft and hard reset, rebooted modem and yet it doesn’t work. Firmware is up to date. I thought it was my ...
DearGeo
Dec 02, 2021Tutor
Netgear CM1150v. - which I stopped using after I got Frontier FiberOptic - which doesn’t need a modem and plugs in from the FiberOptic switch box to RG45 on the back of my router. And even kind of service it doesn’t work. It keeps dropping wired connection. And with FiberOptic there’s no drop signal. Unless there’s an outage or accident that snaps a pole.
My router gets 950 Mbps download and 975 Mbps upload with a ping of 2 ms. So it’s not mine if the ISP I have already mentioned. It’s the router.
michaelkenward
Dec 02, 2021Guru - Experienced User
DearGeo wrote:
Netgear CM1150v.
FURRYe38 asked you what modem you ARE using.
As you should have discovered by now from your earlier misplaced posts in the section for gaming routers, there is no point in providing details that are not relevant. That just confuses people.
Checking the Frontier FiberOptic support section, it seems to have various connection options. With and without MoCA, for example.
FiberOptic Internet and TV Installation Guide | Frontier.com
Every RJ45 "hole in the wall" plugs into something. It isn't always just a socket.
