DearGeo
Dec 02, 2021Tutor
Drop connection
RAX200 Nighthawk keeps dropping wired connection. I have narrowed it down to my router. I have soft and hard reset, rebooted modem and yet it doesn’t work. Firmware is up to date. I thought it was my ...
Dec 02, 2021Guru - Experienced User
What FW is currently loaded?
Try loading up very first version of FW and see if "everything drops".
If it continues, please contact NG support and let them know about what your seeing. Ask them about your RMA options.
- DearGeoDec 02, 2021TutorI updated the routers firmware because I was having said issue. So I went from the previous firmware to the most recent one, filmware Version V1.0.5.132_1.0.69
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
