DearGeo
Dec 02, 2021Tutor
Drop connection
RAX200 Nighthawk keeps dropping wired connection. I have narrowed it down to my router. I have soft and hard reset, rebooted modem and yet it doesn’t work. Firmware is up to date. I thought it was my ...
DearGeo
Dec 02, 2021Tutor
I updated the routers firmware because I was having said issue. So I went from the previous firmware to the most recent one, filmware Version V1.0.5.132_1.0.69
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Dec 02, 2021Guru - Experienced User
Try loading up very first version of FW and see if "everything drops".
- DearGeoDec 03, 2021TutorHow do I do that? And with all the network hacking is that even advisable?
- FURRYe38Dec 03, 2021Guru - Experienced User
Download the FW file from NG support site.
Just to see if the problem continues. IF it does then you'll know.
- DearGeoDec 03, 2021TutorDon’t know if you read up before, I had the older firmware, and it was doing it. So I upgraded and it was still doing it, matter of fact I’ve updated I think twice now. I already know it didn’t work then, or prior and now.
