UgoNet's avatar
UgoNet
Follower
Jul 17, 2026
Dropping connection
Hello, please let us know the fix so the rest of the world with same problem has a clue on what to do. Was it dust blocking the cooling slots? Was it double Nat conflict? Sometimes a fan near the unit helps cool down the cpu if heat is the cause.
Thanks
1 Reply
  • FURRYe38's avatar
    Might be more helpful to know what the issue is...What is dropping? WiFi? Internet services?
    RAX50? This v1 or v2?
    What FW version is loaded on it?
    What's all connected to the router?
    Any top LED indications being seen?
