cyberwasp
Oct 19, 2021Star
Duplicate menus in RAX(50)
Has anyone else notice there are duplicate menus in the basic and advanced tabs?
- Oct 20, 2021
That's normal. All of mine have the option duplicated.
Oct 19, 2021Guru - Experienced User
got an example? (take a screen snip)
Have you tried other browsers?
- cyberwaspOct 19, 2021Star
Yes, I've tried many different web browsers
I'm guessing netgear wrote the website software used here as this board is impossible to find, edit or change anything. The uploaded images are crystal clear in my screen capture. I upload then and it's a blurry mess.
I uploaded the same file to the cloud. A wholevof a lot clearer. https://1drv.ms/u/s!AjZLOy6GbYksgeclEW0BwTr7-v5l8g
- plemansOct 20, 2021Guru - Experienced User
