AHall25
Sep 21, 2021Follower
EAX20 Connection/Usages
In short can you use one of the ports for a connection to the router and the other as ports for wired devices with this in AP mode?
My plan is to connect this via ethernet to my RAX 120 router and then I have one device that would like to plug in via ethernet to this extender (EAX20) once it's in AP mode set up.
Before I purchase the extender I'd like to know if this will work if someone has any expertise on this to give me an answer?
1 Reply
Yes, you can wire the EAX20 into both your router and other devices.
Just make sure during setup to wire it into the router first and run setup for access point mode.
