anthonyng5p
Dec 22, 2020Apprentice
EAX50 Randomly Dropped 5 GHz Channel
I had a very strange occurrence with my EAX50 NetGear Nighthawk router. The 5 GHz WiFi all of a sudden stopped "working". The problem originally manifested itself as the range extender losing Interne...
- Dec 30, 2020
The new firmware did appear on the admin console of the router. I did download it. No problems so far. The 5 GHz band drop was a one-time, real, issue that occurred after months of owning the unit. I suppose I will mark this as "solved", but there have been no replies or others who had a similar problem. I will reply back on this thread if there is an issue.
anthonyng5p
My apologies. This was misstated on the model number. THe model number is the RAX50 Wifi 6 router. I am using firmware version V1.0.2.66_2.0.42.
- plemansDec 22, 2020Guru - Experienced User
There was a whole bunch of fixes in the .72 firmware released.
I'd try installing that, factory resetting, and then doing a clean install (not from a backup because there was so many fixes).
- anthonyng5pDec 23, 2020Apprentice
Thank you for the response. In reading the release notes for the 0.72 firmware update, there are no mentions of any changes to related to wireless or wireless performance. All of the notes suggest small functional changes. I may try the firmware update if it happens again, but I worry about the stability of firmware updates from Netgear. Also, the 0.72 firmware update is only available via the website - why does it not appear via the router admin menus for download?
- anthonyng5pDec 30, 2020Apprentice
