daunois
Oct 12, 2021Aspirant
EAX80 « no internet connection »
Hi, I’ve a strange situation with my EAX80. I’ve an extender deploy in Access Point mode, connected to my router with RJ45, and when I connect to admin interface, it told me that there is no intern...
Oct 12, 2021Guru - Experienced User
What router are you connecting to?
What modem/gateway is the router connected to?
Is it causing an issue?
What firmware version are you on?
Smart connect doesn't need to be disabled if some devices don't have 5ghz. They just won't bandsteer to the 5ghz. You'd still be able to use it fine.
