dcinca
Nov 03, 2020Apprentice
EAX80 2.4GHz only 20Mhz??
EAX80 Firmware:1.0.1.62_1.0.1 I have a couple questions: 1. 2.4G is only running in 20Mhz. Is this a Bug? 2. And also I found "Enable OFDMA in 2.4GHz" and "Enable OFDMA in 5GHz" in the debug pa...
Nov 04, 2020Guru - Experienced User
do you live in a congested area (apartment, condo, home with other homes close to it)?
If so, most routers have a 20/40mhz coexistence setting. It prevents the 2.4ghz from broadcasting in 40hz if there's to many signals. This helps everyone's network to run better over 2.4ghz because of its limited bandwidth and overlap of wireless signals.
You can disable this setting but if you live in a congested area, it just makes things worse for your neighbors (and potentially you). Tends to be a a**hole move in those cases.
So even if the router is set to 40hz 2.4ghz channels, if thats enabled, it can just be broadcasting on 20hz.
https://kb.netgear.com/30228/How-to-disable-20-40-MHz-Coexistence-on-a-NETGEAR-router
dcinca
Nov 05, 2020Apprentice
Thank for your reply. But my rax120 had that 20/40mhz been disabled. The 2.4G signal from Rax120 is 40Mhz, but the 2.4G signal from Eax80 is only 20 Mhz. And there is no any 20/40Mhz options in the Eax80 settings.
