dcinca
Nov 03, 2020Apprentice
EAX80 2.4GHz only 20Mhz??
EAX80 Firmware:1.0.1.62_1.0.1 I have a couple questions: 1. 2.4G is only running in 20Mhz. Is this a Bug? 2. And also I found "Enable OFDMA in 2.4GHz" and "Enable OFDMA in 5GHz" in the debug pa...
dcinca
Nov 05, 2020Apprentice
Thank for your reply. But my rax120 had that 20/40mhz been disabled. The 2.4G signal from Rax120 is 40Mhz, but the 2.4G signal from Eax80 is only 20 Mhz. And there is no any 20/40Mhz options in the Eax80 settings.
dcinca
Ok, I changed the region from Australia to US, the 2.4G is back on 40Mhz. It's a bug.
- NewfiedroolNov 05, 2020Virtuoso
Out of interest did you disable the coexistence on your RAX120 or did it allow 40Mhz due to the lack of neighbouring channels?
