flyingcrane89's avatar
Jul 14, 2020
eax80 conflicts with ex7700
When both ax600 and ac2200 extenders are connected wireless connectivity randomly drops. Condition clears when either is turned off.
  • plemans's avatar
    Jul 14, 2020
    Are you using them both in mesh mode? (same ssid)
    Are they in range of each other?
    Usually if people need more than 1 extender, its better to run with a full mesh system like orbi that has a controller. The extenders don't have anything controlling them so can end up connecting to each other and not back to the router.
    If that's the case, set one of them with its own unique ssid and it should fix the problem.
