Ts937km
May 18, 2020Apprentice
Empty Attached Devices list on RAX120 - Firmware Version V1.0.1.122
After upgrading to Firmware Version V1.0.1.122 my attached devices list is empty. I was wanting to create a static address on a new device. Tried chrome, Firefox. Safari on multiple computers. Cl...
Ts937km
May 21, 2020Apprentice
Thanks.
Updates shouldn't require a factory reset. That isnt a update in my eyes.
i rolled back to .118 and all is fine. For me at least. I'll try again when it's easier to get replacement routers etc.
mixxon
Jun 18, 2020Tutor
Same issue here! Ts937km How did you roll back? Where is older firmware to find?!
- Ts937kmJun 18, 2020Apprentice
https://www.netgear.com/support/product/RAX120.aspx
Click on Downloads
Click on Previous Versions
I went back to 1.0.1.118 and everything is fine. And has been since that day. Didnt have to reset my router to defaults or anything.
Good luck!
- mixxonJun 18, 2020Tutor
That did the trick! Now I can enable portfowarding again and see all the connected devices. Thank You! Ts937km :smileyvery-happy:
Good to hear. Make sure to turn off automatic updates. And keep a copy of that firmware.. And backup your settings with that firmware running.. When they release another firmware I will try again I guess.
