JuanMaddox
Jul 11, 2020Follower
Empty Attached Devices list on RAX120 - Firmware Version V1.0.1.122??
After upgrading to Firmware Version V1.0.1.122 my attached devices list is empty. I was wanting to create a static address on a new device. Tried chrome, Firefox. Safari on multiple computers. Cl...
Jul 11, 2020Guru - Experienced User
I'd first try a simple factory reset. Maybe an old setting is causing the issue.
If that doesn't work, you can downgrade the firmware a version. Maybe the newer one introduced an issue.
- PistoleAug 04, 2020Guide
I have excactly the same problem.
I was working on Firmware Version V1.0.1.122.
Today I did a factory reset because I wanted to clean install the router. After the reset the devices list on my MacBook kept empty and I cloud not create any port forwardings.
On the IOS app the list was normal filled.I have installed the previous Firmware Version V1.0.1.115 and the list was again filled with my devices. I updated again to Firmware Version V1.0.1.122 and the list was again empty.
Rest me no other option than again go back to Firmware Version V1.0.1.115 and keep working on that version.
There is something very broken in the Firmware Version V1.0.1.122.
