Retired_Member
Dec 11, 2020Emty openvpn files on the Nighthawk RAX40
Hello Netgear community, Last summer i bought the nighthawk RAX40 wifi 6 router, everything is working great except the vpn server. When i enable the vpn server and download the configuration fil...
Christian_R
Dec 16, 2020NETGEAR Employee Retired
Hello,
Please refer to page 131 of the user manual linked below to set up a VPN connection on the RAX40.
https://www.downloads.netgear.com/files/GDC/RAX40/RAX40_UM_EN.pdf
Christian
ToVine
Mar 06, 2021Initiate
Hi Christian,
This reply doesn't help - as the original poster said, all the files in the config archives downloaded from the router web interfaces are empty; there is no certificate or key data so connection is impossible.
Is there a way to fix this, or could you release a new firmware version that's not broken?
