Moose-Squirrel
Sep 18, 2022Tutor
Enable AX first time issues
I've had AX enabled and never detected it as an issue until today when setting up a laptop with new intel wifi that is supposed to handle AX. Turns out others are having issue too. Oddly it would con...
Moose-Squirrel
Sep 19, 2022Tutor
Already got the intel driver and did not help. Odd that all my other devices do not complain about AX or have trouble connecting with it turned on.
They surely could have used better words to say the wifi is on since AP also represents so many other things, especially when you search the manual.
Sep 19, 2022Guru - Experienced User
What intel card is it?
Usually if only 1 device is having an issue, its more related to something with that device versus the router.
