psychopomp123
Dec 30, 2019Luminary
Enable Mu-Mimo on RAX200
Just a heads up if you're using a RAX200: Mu-Mimo is NOT enabled by default. You have to manually switch this on by going to ADVANCED > Advanced Setup > Wireless Settings > Enable Mu-Mimo Wi...
psychopomp123
Dec 31, 2019Luminary
Even if there's no benefit to my PCE-AC88U, i still have other 2x2 Mu-Mimo clients such as Nvidia Shield TV box, Samsung S10, iphone X and iphone XS connected to the RAX200 so I'm going to leave the Mu-Mimo setting on. As I said, it seems to have improved the wireless speeds wrt stable throughput.
avtella
Dec 31, 2019Prodigy
You are confusing MU-MIMO with standard MIMO, iPhones and the nvidia shield don’t support MU-MIMO and the Broadcom chip in the Galaxy phones had an issue where they intermittently dropped to single stream mode with MU enabled.
Also if devices are too close to each other MU does not work, SmallNetbuilder already did enough testing on this, if it’s not harming leave it on but NG made the right decision by leaving it off since this is a Broadcom router.
- avtellaDec 31, 2019ProdigySeems like a placebo effect sorry to say.
- psychopomp123Dec 31, 2019Luminary
Well I was getting worse wifi performance on the RAX200 with Mu-Mimo turned off compared to my Linksys EA9500v2 (which has Mu-Mimo enabled by default). Now with Mu-Mimo enabled on the RAX200, wifi performance on both is identical, ie excellent.
- avtellaJan 01, 2020ProdigyI still say placebo, I suggest you read how MU actually works. Just because you enabled it doesn’t mean it’s doing anything unless it can form an MU group of two or more MU clients. And you also need a decent separation of at least like 5ft between two MU capable client devices for it to even work properly.
I have an RAX80. The RAX80 is practically the same as the RAX200 as it uses the same WiFi chipset and CPU minus the extra 5Ghz band, I actually have 5 MU capable clients (3x laptops with an Intel AX200 WiFi card and 2x laptops with an Intel 8265 AC WiFi card and as expected it didn’t do much on the RAX80 and at times performance was much worse when doing parallel WiFi based LAN transfers to and from my NAS.
Now with the Qualcomm based R7800 and RAX120 there was a tangible notice in certain conditions with MU enabled, but it wouldn’t say cal it a night and day difference.- psychopomp123Jan 02, 2020Luminary
"The RAX80 is practically the same as the RAX200 as it uses the same WiFi chipset and CPU minus the extra 5Ghz band"
Isn't that a bit like saying a BMW 1 series is the same as a BMW 7 series minus xxx? Yes, I'm well aware that the RAX 80 uses the same chipset as the RAX200 and if I needed a dual-band router then i would have gone for the RAX80 or RAX120. But I didn't. I wanted a tri-band router due to shed load of wifi devices connected simultaneously (~50). My previous routers (Linksys EA9500v2 & Asus RT-AC5300) have all been tri-band so i find it hugely beneficial to manually allocate clients to each of the 3 bands. I don't think I will ever go back to a dual-band router ever again :)
