Ilias83's avatar
Ilias83
Guide
Jan 15, 2024
Enable Telnet to Change Region on RAX70
Hello, I'm from Greece and recently bought a second hand RAX70. Unfortunately the Region is locked to China even though the router box clearly says RAX70-100EUS. (I thought that it was made for EU...
  • Ilias83's avatar
    Jan 16, 2024
    I finally got it to work.
    I enabled Telnet and changed Region to Europe!
    Now I have the 4804MHz option!
    I managed to do it with Firmware Version 1.0.10.110 running the code I found here:
    https://github.com/bkerler/netgear_telnet
    I run the:
    python3 telnet-enable.py [IP] [MAC] [user] "[password]"
    Double quotes instead of single quotes in readme file might made the trick.
    Many thanks to Bjoern Kerler!
