Ilias83
Jan 15, 2024Guide
Enable Telnet to Change Region on RAX70
Hello, I'm from Greece and recently bought a second hand RAX70. Unfortunately the Region is locked to China even though the router box clearly says RAX70-100EUS. (I thought that it was made for EU...
- Jan 16, 2024
I finally got it to work.
I enabled Telnet and changed Region to Europe!
Now I have the 4804MHz option!
I managed to do it with Firmware Version 1.0.10.110 running the code I found here:
https://github.com/bkerler/netgear_telnet
I run the:
python3 telnet-enable.py [IP] [MAC] [user] "[password]"
Double quotes instead of single quotes in readme file might made the trick.
Many thanks to Bjoern Kerler!
schumaku
Jan 15, 2024Guru - Experienced User
Have an eye on http://www.antinode.info/ftp/nte/nte-07/ ... especially the readme ... which shows how to call nte with some (==the right) parameters like MAC address, the password, ...
VMS forever antinode 8-)
microchip8
Jan 15, 2024Master
Telnet has been removed from the firmware long time ago. It's a black box now.
