Ilias83
Jan 15, 2024Guide
Enable Telnet to Change Region on RAX70
Hello, I'm from Greece and recently bought a second hand RAX70. Unfortunately the Region is locked to China even though the router box clearly says RAX70-100EUS. (I thought that it was made for EU...
- Jan 16, 2024
I finally got it to work.
I enabled Telnet and changed Region to Europe!
Now I have the 4804MHz option!
I managed to do it with Firmware Version 1.0.10.110 running the code I found here:
https://github.com/bkerler/netgear_telnet
I run the:
python3 telnet-enable.py [IP] [MAC] [user] "[password]"
Double quotes instead of single quotes in readme file might made the trick.
Many thanks to Bjoern Kerler!
Ilias83
Jan 16, 2024Guide
I run the:
Danc90
Jan 16, 2024Initiate
Nice one. Were you able to see the second wifi network after enabling 4800mbps?
My RAX70 was region locked to Australia. I flashed version V1.0.1.68 (initial firmware) from the support page. This enabled me to select region on the Wireless Setup page and a few other options such as open vpn. I changed region to Europe and then I was able to select 4800mbps on the second 5ghz. It successfully changes settings but I can't connect to that network. I then updated to the latest firmware V1.0.15.146 and all the options were still available, but no luck seeing the second 5ghz SSID.
- plemansJan 16, 2024Guru - Experienced User
Someone managed it with a RAXE500 so it might be possible
Re: RAXE500 region lock - NETGEAR Communities
