Ilias83
Jan 15, 2024Guide
Enable Telnet to Change Region on RAX70
Hello, I'm from Greece and recently bought a second hand RAX70. Unfortunately the Region is locked to China even though the router box clearly says RAX70-100EUS. (I thought that it was made for EU...
- Jan 16, 2024
I finally got it to work.
I enabled Telnet and changed Region to Europe!
Now I have the 4804MHz option!
I managed to do it with Firmware Version 1.0.10.110 running the code I found here:
https://github.com/bkerler/netgear_telnet
I run the:
python3 telnet-enable.py [IP] [MAC] [user] "[password]"
Double quotes instead of single quotes in readme file might made the trick.
Many thanks to Bjoern Kerler!
Danc90
Jan 16, 2024Initiate
Update: Make sure to reboot after changing region and speed. It took 5-10 mins and the SSID of 5ghz-2 finally appeared. I am now getting 2402/2402Mbps (Europe region, 4800Mbps mode, 128DFS) on some devices, up from previous 1200/1200Mps (Australia region, 2400Mbps mode). Currently using Firmware Version 1.0.5.108.
schumaku Smart Connect is off by default. I have left it disabled. I left out the screenshot of 5ghz-1. All three radios have options.
schumaku
Jan 17, 2024Guru - Experienced User
Great! Still try to understand and explain the readers here why Netgear can not make the 480x Mbps mode available for Australia (and Canada). There is no continuous 5 GHz channel range available in the regulations - the most obvious limitation is in the notch for Channels 120...128. This does very likely prohibit operating the system on 160 MHz bandwidth To reach 2402/2402Mbps max on just 80 MHz, one would need to use 4x4 clients - there are not many "out there". The popular and reliable Inhell AX and BE modules are 2x2 only.
For my part, I'm just a "tire kicker" here in the consumer router section, more in Netgear SMB networking, and a co-editor of the https://en.wikipedia.org/wiki/List_of_WLAN_channels.
-Kurt
Zurich, Switzerland
