back_matt
Jun 13, 2020Follower
Enable Wireless Router Radio check boxes.
the check boxes to enable wireless radio are dim. They will not allow me to check on or off
1 Reply
Not much to go on there. Tell us more.
Where are you looking? What are you using?
Is the wifi working?
What to the wifi LEDs look like?
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reason.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware for your device.You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Nighthawk WiFi Routers
Your device doesn't do "AX".
