JasonArbaugh
Aug 18, 2020Follower
Enabling RAX80 Link Aggregation Break WiFi
I recently upgraded the home network because I am WFH like most everyone else. After running ethernet through my attic (in Texas), dropping the cables through the walls, and configuring two new Netg...
schumaku
Sep 09, 2020Guru - Experienced User
hotwke Suspect you mix the LAN LAG with the Internet LAG config to conect a cable modem suppoting LAG.
Nighthawk AX8 User Manual p.87, "Get Multi-Gig Internet With Internet Port Aggregation"
"3. Connect the Internet port and Ethernet port 1 on your router to two Ethernet ports on your modem."
hotwke
Sep 17, 2020Aspirant
Thank you!! Yes, I was mixing them!! Was so excited to try out the CM1200 and just.... You know. Haha *Smacks forehead*
