sfloess
Dec 20, 2020Aspirant
Enabling telnet in the RAX75?
Anyone know how to enable telnet on the RAX75? The telnetable.bin trick as well as [ip]/debug.html does not work... Thanks ahead of time!
antinode
Dec 20, 2020Guru
> [...] My creds, mac address and ip are correct for telnetenable.bin.
Which of its MAC addresses did you specify?
> [...] If tney are going to stop supporting it, thejr firmware is
> useless to me.
When did they _start_ "supporting it"?
> I alsoopened a case - [...]
Please report any interesting results.
sfloess
I tried the following mac addresses:
- the mac address as denoted on the router itself (underneath)
- hit the router with nmap: that provided an addtional mac address
- the internet mac address
I also tried using colons and no colons in the mac addresses when issuing telnetenable.bin
I am not suggesting it was ever supported. More so, I have two R9000s that do have this capability (I've since moved those over to DD-WRT). My point is, I am somewhat hobbled using their stock firmware. The AX75 is not supported on the DD-WRT site (no mention in the router database...nor do I see it under the beta downloads at ftp.dd-wrt.com/betas/2020)...
Most definitely! I'm working around the firmware via my R9000s (as in putting my required functionality on them). Still rather annoying...
I must confess I do use my routers like computers and have a bunch of wireless client bridges around my home (long story). Having the ability to run chroot'd debian and/or entware is very nice...
- antinodeDec 20, 2020Guru
The one you want is the LAN MAC address (not WAN/Internet):
ADVANCED > ADVANCED Home : Router Information : LAN Port : MAC Address> I also tried using colons and no colons in the mac addresses when
> issuing telnetenable.binIf you want to keep the colons, you can use the program which I
modified: http://antinode.info/nte/ So far as I know, others are too
lame to allow them.> I am not suggesting it was ever supported. [...]
"stop supporting it" certainly suggested that to me. Hard to stop
something which was never started.> [...] Having the ability to run chroot'd debian and/or entware is very
> nice...
I suspect that Netgear dislikes the resulting support problems.
Releasing firmware with fewer defects/shortcomings would help, but
that's more work.- sfloessDec 20, 2020Aspirant
> ADVANCED > ADVANCED Home : Router Information : LAN Port : MAC AddressAw geez, missed the scroll bars!
Tried that one too...no good :(
> "stop supporting it" certainly suggested that to me. Hard to stop something which was never started.
Not following you here...but OK
> I suspect that Netgear dislikes the resulting support problems. Releasing firmware with fewer defects/shortcomings would help, but
that's more work.Yep
- sfloessDec 27, 2020Aspirant
Update on my situation: I spoke to "technical" support (note the quotes) - took a few emails and then finally I called after hearing nothing back. As far as I can tell, based upon the "technical" support person, enabling telnet is not possible.
Is it me, or does Netgear have the worst (or one of the worst) "technical" support departments? How embarrassing for Netgear as a company.
