Chazzypads
Jul 01, 2020Aspirant
Entire factory firmware
Looking for a link or place to find factory firmware to replace DD WRT in my X10 nighthawk. The firmware upgrade on the website is not the whole firmware package. I bought a "factory refreshed" unit ...
Jul 01, 2020Guru - Experienced User
Chazzypads wrote:Looking for a link or place to find factory firmware to replace DD WRT in my X10 nighthawk. The firmware upgrade on the website is not the whole firmware package. ---why don't you think its the whole package? I bought a "factory refreshed" unit with dd-wrt on it. I love DD WRT but am looking to replace and play with the factory firmware first. THANKS
What makes you think the firmware on the support site isn't the whole firmware?
Your only issue would be to check the dd-wrt forum for the best way back to stock firmware without bricking the device.
- ChazzypadsJul 01, 2020Aspirant
Thanks but the update does nothing. Will check dd wrt website thank you
