camge
Nov 26, 2024Aspirant
ERR_CONNECTION_TIMED_OUT RAX70
Heloo all, After researching here and trying some solutions, I've resulted to posting. W11 firmware: V1.0.15.146 IP6 is enabled ISP auto I've been having this issue of some websites timin...
Nov 27, 2024Guru - Experienced User
W11? Windows 11?
Same thing happen if you disable IPv6?
When IPv6 are you using auto detected IPv6 DNS or custom IPv6 DNS?
What ISP AUTO?
What ISP are you connected with?
Does using ISP auto detected DNS exhibit same condition?
Try using Cloudfare, or Google or Quad 9 DNS as a custom DNS setting on the router.
Does this happen with all devices connected to the router?
Directly connect to the CM modem to see if a wired PC gets same problem or not?
- camgeNov 27, 2024Aspirant
FURRYe38 wrote:W11? Windows 11?
- yes Windows 11
- IPv6, I had disabled, turned it on in hopes that was issue, no luck. Used both auto and after reading a similar post, used manually goodle dns 8888, 2001xx, etc
What ISP AUTO?What ISP are you connected with?
- Auto ISP yes, using COX, DNS is auto
- Yes, same issue. Yes tried using google dns manual settings, per another post but same issue, all devices using wifi
- Direct connected to modem via ethernet to computer and problem goes away.
- FURRYe38Nov 27, 2024Guru - Experienced User
Try a factory reset and setup from scratch on the RAX router using a wired PC and web browser.
Well this is interesting:
I direct connected PC to modem, off/on modem, went to issue websites and came up instantly, so started working on some sites, while making changes, all of a sudden, connection to website timed out! Went back to server webiste and exact same thing, all timed out.
Oddly, another server I have, with websites that werent working earlier, is still working fine
what the...., the issue websites just came back up, now they are working. What the heck is happening?
now they're timing out again... ugh
Could it be my ISP?
Maybe change or have them reset service?
driving me nuts
