camge
Nov 26, 2024Aspirant
ERR_CONNECTION_TIMED_OUT RAX70
Heloo all, After researching here and trying some solutions, I've resulted to posting. W11 firmware: V1.0.15.146 IP6 is enabled ISP auto I've been having this issue of some websites timin...
camge
Nov 27, 2024Aspirant
FURRYe38 wrote:W11? Windows 11?
- yes Windows 11
Same thing happen if you disable IPv6?
When IPv6 are you using auto detected IPv6 DNS or custom IPv6 DNS?
- IPv6, I had disabled, turned it on in hopes that was issue, no luck. Used both auto and after reading a similar post, used manually goodle dns 8888, 2001xx, etc
What ISP AUTO?What ISP are you connected with?
- Auto ISP yes, using COX, DNS is auto
Does using ISP auto detected DNS exhibit same condition?
Try using Cloudfare, or Google or Quad 9 DNS as a custom DNS setting on the router.
Does this happen with all devices connected to the router?
- Yes, same issue. Yes tried using google dns manual settings, per another post but same issue, all devices using wifi
Directly connect to the CM modem to see if a wired PC gets same problem or not?
- Direct connected to modem via ethernet to computer and problem goes away.
Nov 27, 2024Guru - Experienced User
Try a factory reset and setup from scratch on the RAX router using a wired PC and web browser.
