camge
Nov 26, 2024Aspirant
ERR_CONNECTION_TIMED_OUT RAX70
Heloo all, After researching here and trying some solutions, I've resulted to posting. W11 firmware: V1.0.15.146 IP6 is enabled ISP auto I've been having this issue of some websites timin...
camge
Dec 04, 2024Aspirant
Well, nothing was working or fixed, so my solution was to purchase another router and try it.
just install a nother brand to test and all my sites are visible once again. Now have to send in the RAX70 router for either defective or service?
Dec 05, 2024Guru - Experienced User
Is protection engine feature seen on the RAX70 web page?
- camgeDec 05, 2024Aspirant
I went back to the RAX70 to see if maybe the firmware settings needed update but, they are up to date.
Where is that setting? I looked and dont see that option setting in security.
- FURRYe38Dec 05, 2024Guru - Experienced User
Ya, I checked my RAX80 and seems that the 70 and 80s dont' have Protection Engine so you can skip that check.
