sjw480
Aug 22, 2021Aspirant
Erratic performance of 2.4mHz Wi-fi channel in RAX50
I am running the Netgear Nighthawk RAX50. By matter of choice I have separate SSID's for 2.4 and 5 MHz. It was working fine for months. We have a number of Smart home devices that connect at 2.4. Sev...
Aug 30, 2021Guru - Experienced User
a couple things you can try.
1. downgrade the firmware. Maybe the newer firmware introducted a bug.
2. factory reset. maybe an old setting is causing an issue. a factory reset/reinstall can sometimes fix that
