bbbobbya10
Nov 24, 2020Aspirant
Error 5478EH Model RAX35
Trying to intall router using app and when scanned it came up with Error 5478EH.Called support and said something about needed firewall but did not fully inderstand about this.Model RAX35 but this w...
Nov 24, 2020Guru - Experienced User
I'd hardwire into the router for setup. Use a pc/laptop. It tends to go smoother/easier.
- bbbobbya10Nov 24, 2020Aspirant
Not exactly sure on how to do that. Is it hooking the Ethernet cable directly from router to PC bypass the modem .
- plemansNov 24, 2020Guru - Experienced User
its not "bypassing" the modem.
You connect your modem to the wan port on router.
You connect a router lan port to a pc/laptop.
