Samuel_Chow
Jan 18, 2021Aspirant
Error: Unable to establish WAN aggregation.
Hello, Anyone have idea why i keep getting this error message? "Error: Unable to establish WAN aggregation." I have tried to plug in the plan cable in to Multi-gigabyte+WAN WAN+LAN1 LAN1...
Jan 18, 2021Guru - Experienced User
What supplier modem are you using?
Samuel_Chow
Hi, thank you for your reply.
The modem I use is provided by my internet supplier, it’s Huawei echolife hg8040h5.
Maybe this is the problem?
I am thinking of getting the CM2000 but I am not sure if this is a must for WAN aggregation, since this product don’t even sell in HK
- plemansJan 19, 2021Guru - Experienced User
You'd have to check if the cm2000 was supported for your isp. If you have the hg8040h5, you're on fibre.
And I couldn't find if that gateway even supports port aggregation.
- Samuel_ChowJan 19, 2021AspirantOh i see, so the problem is most likely my modem don’t support aggregation, yes I’m on fiber, if they support cm2000 all I have to do is switch the modem? Thanks a lot.
I doubt they support the cm2000. Its a cable modem and not a fibre.
But you're welcome to ask them.
