aoneill1223
Feb 28, 2024Aspirant
Ethernet connection drops while gaming
I recently upgraded to a Nighthawk AX30 router with Spectrum 1gig internet service. My pc is connected by Ethernet to the router and while gaming, the connection randomly drops and then resets after s...
Feb 28, 2024Guru - Experienced User
Is this a RAX30?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the brand and model# of the ethernet adapter in the one PC?
Does this happen with another ethernet connected PC?
microchip8
Feb 28, 2024Master
Have you done a factory reset and reconfigue from scratch?
- aoneill1223Feb 28, 2024AspirantYes I’ve reset everything and had spectrum reset the connection as well.
