aoneill1223
Feb 28, 2024Aspirant
Ethernet connection drops while gaming
I recently upgraded to a Nighthawk AX30 router with Spectrum 1gig internet service. My pc is connected by Ethernet to the router and while gaming, the connection randomly drops and then resets after s...
Feb 28, 2024Guru - Experienced User
Is this a RAX30?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the brand and model# of the ethernet adapter in the one PC?
Does this happen with another ethernet connected PC?
aoneill1223
Yes its the RAX30 with firmware version V1.0.10.94_3.
Spectrum Modem: Sercomm Docsis 3.1 EMTA Cable Modem 2.5 Gbps
Im going to replace the ethernet cable between modem and router when it arrives tomorrow as I'm using the flat ethernet that came with the modem. But I'm not sure it's that because all of our devices on wifi never disconnect.
The ethernet connection is through the motherboard which is an ASUS PRIME
B760M-A AX with the Realtek Gaming 2.5GBE family controller.
This is the only PC in the house.
- FURRYe38Feb 28, 2024Guru - Experienced User
Does the Internet LED on the router change color when this happens?
I'd be sure to update the drivers from Realtek themselves to be sure.
- aoneill1223Feb 28, 2024Aspirant
The led lights all stay the same as normal. I've made sure those drivers are up to date and havent seen any updates go through for them. This all started when we switched from 500mb to 1gig internet speeds and I replaced the spectrum router with the RAX30.
So it keeps disconnecting tonight and while looking at the event viewer for the realtek family controller, i have mulitple Kernel PnP 400, 411 and 430 errors showing up at the times it disconnects.
- KitsapFeb 28, 2024Master
aoneill1223 wrote:Yes its the RAX30 with firmware version V1.0.10.94_3.
B760M-A AX with the Realtek Gaming 2.5GBE family controller.This is the only PC in the house.
Take a close look at the old Ethernet cable to see if there are any category ratings indicated. The part about flat Ethernet is a red flag.
