RobbieGibbs21
Mar 13, 2025Aspirant
Ethernet Disconnects from PC Windows 11 - AX5300
Hello, I have been having an issue for over a year or so where my ethernet disconnects and reconnects seemingly at random. Some days it doesn't do it, other days it does it a lot. I have tried diffe...
RobbieGibbs21
Mar 15, 2025Aspirant
I built this computer almost 2 years ago, the intel chip is a (I226-V #2), it does have reported issues and intel support suggested I RMA the motherboard or try a USB dongle. I'm hesitant to take apart the PC and return just the motherboard being that I use this desktop for work everyday.
Coincidently though, my housemate's desktop does have a killer network card and he uses mainly WIFI. He has horrible connection on 2.5G or 5G, frequent drops in connection and I even tried getting him a TP-Link USB WIFI adaptor with the same result. I am at a loss with his problems as well.
Kitsap
Mar 15, 2025Master
I would definitely hold off on taking apart your PC to RMA the motherboard.
The test with the USB adapter was a very good reference data point. I paid $20 for the Amazon basic 1 Gbps version I have.
PCIE Ethernet adapters for 1 Gbps are also listed in the $20 range.
With problems on two machines, using the Ethernet port, USB adapter, and Wi-Fi, I am prone to look at the ISP for a solution with the modem rebooting.
Are you located in a single family dwelling or in a multi-family complex?
If a single family dwelling, you should have access to the coax connections from your modem to the point where the ISP connection is made. There may be some ideas in this reference document link: https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html .
- RobbieGibbs21Mar 15, 2025Aspirant
It's a townhouse shared by 4 units. Only difficult thing is the owner for our unit is in control of the internet for specific reasons. I'll have to have some specific tasks when I call him to talk to my ISP.
The coax cable in our unit goes straight into the ceiling which is odd because I don't know of a way to access the attic.
I suppose I could mention some of the oddities in the modem connections and have them take a look.
