joe_wht
Jun 18, 2021Luminary
Ethernet Port link aggregation
I've been trying th Ethernet Port link aggregation & the 2.5 gig Multi gig port options. When trying the aggregation on mhy ReadyNAS 214 it Slows my web browsing & File access WAY DOWN!! When tryi...
- Jun 18, 2021
To be more specific, for your setup, I would recommend the following.
- Enable Ethernet port aggregation on the RAX200 and connect ports 1 and 2 to the 2 Ehternet ports on the NAS (having its Ethernet aggregation enabled as well) (usually the "new bond" setting in the network settings tab of the readyNAS and it will need to bond using layer 2+3). Many ReadyNAS devices will not auto detect a link aggregation, thus it has to be enabled in the network settings, otherwise it will just use one or the other port but never both at once.
- Using either Ethernet port 3 or 4 of the router, connect it to your 16 port gigabit switch.
- For the multi-gig port, check if your main PC has a 2.5GbE or better Ethernet port, if not, then buy a NIC such as an RTL8125 based one, the prices fluctuate a lot, but on a good week, you can find some in the $12-15 range, and on a bad week, they can be in the $25 range). You will then connect the multi-gig port to your main PC so that it will have the full 2Gbps from the NAS when performing backups and other transfers.
- For your WiFi clients, your main laptop should have a good 802.11ax WiFi adapter, if needed, upgrade to an Intel AX200 WiFi adapter (typically around $17-$19), of it you want to eventually move to the 6GHz band, then the Intel AX210 which will go for about $25-$30. If in the same room as the router on the 5GHz band, you will get around 1.8Gbps real world throughput, and often depending on the building materials and room size, you can still hold over 1Gbps even 1-2 rooms away.
Razor512
Jun 18, 2021Prodigy
- joe_whtJun 19, 2021Luminary
Thanks for that info !! ..
Question.. In prior years Qos created problems.
With the Nighthawk RAX200 will Qos properly work?
The RAX200 does handle my Nest cams dang good,
Much better than the R8500 & prior routers. Even through
I had priorities set on everything.
I've got the front 5 cams divided between the 5Ghz
and the rear cams on 2.4.
-- Just wondering if I should turn Qos back on.
- Razor512Jun 19, 2021Prodigy
For the QOS if set up properly, along with the right connection, it can work well.
One of the main issues with current implementations of QOS for all major routers, is the requirement that the upload and download throughput be specified. In my case, QOS works great since I have a fiber internet connection (verizon fios) where the throughput is consistent throughout the day. With some ISPs, e.g., some cable providers, depending on the area, and if there is any competition or not, you can be on an oversold node where the throughput fluctuates throughout the day. This means that whatever speed you set the QOS to, will be in accurate relative to the actual throughput.
While you can set the speeds to the lowest common denominators, it will mean that your speeds end up being capped by the QOS setting. Or if you set it to the average or peak speeds, then during the times when the set speed matches or is lower than the actual throughput, then QOS will actually perform some traffic shaping, but in the times when the actual throughput is lower than the QOS specified speeds, then even when enabled, the QOS will not have a noticeable impact on the connection, and it will not fix congestion issues.
If your ISP has very inconsistent speeds, then I recommend not enabling QOS, as you will end up with it not doing anything, or you will end up with it capping your speeds depending on the values set.
If your speeds are pretty consistent, then try enabling it and doing a few tests such as a large download while streaming video.
PS, for the nighthawk series, they still do not give granular control over the QOS entries, instead they use a L7 filter database where priorities are assigned to a huge range of traffic types, and it identifies the type of traffic and assigns a priority. While it is quite thorough, one area that I wish Netgear would provide more info on, is how exactly does it prioritize uncategorized traffic relative to bulk traffic. For example, if you are using some obscure service that is not in the database, and you are also downloading a bunch of games or anime, will the bulk traffic be prioritized below that of the uncategorized traffic?
Gottcha.. I'll leave it alone.
When I'm not home my cams are divided up between the 3 wifi networks.
When home only the front cams are on and 90% of what I use is ethernet connected.
I do have a lot of wifi plugs, all on 2.4 that are just sitting & waiting to be used.
Thanks so much for sharing your knowledge !!
- Joe
